Отправлено 22 Июнь 2010 - 23:10
Дата: Fri, 23 Jul 2010 20:11:53 +0000
Номер ошибки: 1366
Ошибка: Incorrect integer value: '' for column 'icon_id' at row 1
IP Адрес: 95.84.5.178
Страница: /index.php?
1 =>
array (
'file' => 'C:\\www\\htdocs\\ips_kernel\\classDb.php',
'line' => 1104,
'function' => 'query',
'class' => 'db_driver_mysql',
3 =>
array (
'file' => 'C:\\www\\htdocs\\admin\\applications\\forums\\sources\\classes\\post\\classPost.php',
'line' => 967,
'function' => 'insert',
'class' => 'db_main_mysql',
4 =>
array (
'file' => 'C:\\www\\htdocs\\admin\\applications\\forums\\modules_public\\post\\post.php',
'line' => 278,
'function' => 'addReply',
'class' => 'classPost',
5 =>
array (
'line' => 256,
'function' => 'saveForm',
'class' => 'public_forums_post_post',
6 =>
array (
'file' => 'C:\\www\\htdocs\\admin\\sources\\base\\ipsController.php',
'line' => 291,
'function' => 'doExecute',
mySQL query error: INSERT INTO bbbposts (author_id,use_sig,use_emo,ip_address,post_date,icon_id,post,author_name,topic_i
d,queued,post_htmlstate,post_key,post_parent) VALUES(1,1,1,'95.84.5.178',1279915913,'','fsfsdfsfs','raYer',1,0,0,'629f35b426c03fe14049e30ef3c79ae5',0)
