Перестали работать задачи
По какой то причине перестали работать выполнение задач.
Стояло выполнение задачи по cron. После пробовал запускать вручную и автоматически по трафику. Но задачи так и не выполняются, также на почту приходить начала эта ошибка, если выполнение задачи происходит по cron, до этого все работало нормально и тут резко перестало:
В чем может быть проблема?
Exception:
IPS\Db\Exception Object
    [query] => UPDATE `core_queue` core_queue SET `offset`=? WHERE id=?
    [binds] => Array
            [0] => 0
            [1] => 12509
    [message:protected] => MySQL server has gone away
    [string:Exception:private] =>
    [code:protected] => 2006
    [file:protected] => /home/users/n/nizhniy-shkaft/domains/domain/system/Db/Db.php
    [line:protected] => 631
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /home/users/n/nizhniy-shkaft/domains/domain/system/Db/Db.php
                    [line] => 1150
                    [function] => preparedQuery
                    [class] => IPS\_Db
                    [type] => ->
                    [args] => Array
                            [0] => /*IPS\_Task::runQueue:43*/ UPDATE `core_queue` core_queue SET `offset`=? WHERE id=?
                            [1] => Array
                                    [0] => 0
                                    [1] => 12509
            [1] => Array
                    [file] => /home/users/n/nizhniy-shkaft/domains/domain/system/Task/Task.php
                    [line] => 69
                    [function] => update
                    [class] => IPS\_Db
                    [type] => ->
                    [args] => Array
                            [0] => `core_queue` core_queue
                            [1] => `offset`=?
                            [2] => WHERE id=?
            [2] => Array
                    [file] => /home/users/n/nizhniy-shkaft/domains/domain/applications/core/tasks/queue.php
                    [line] => 43
                    [function] => runQueue
                    [class] => IPS\_Task
                    [type] => ::
                    [args] => Array
            [3] => Array
                    [line] => 356
                    [function] => IPS\core\tasks\{closure}
                    [class] => IPS\core\tasks\_queue
                    [type] => ->
                    [args] => Array
            [4] => Array
                    [line] => 55
                    [function] => runUntilTimeout
                    [type] => ->
                    [args] => Array
                            [0] => Closure Object
                                    [this] => IPS\core\tasks\queue Object
                                            [caches:protected] => Array
                                            [_data:protected] => Array
                                                    [id] => 5
                                                    [app] => core
                                                    [key] => queue
                                                    [frequency] => P0Y0M0DT0H1M0S
                                                    [next_run] => 1583475938
                                                    [running] => 1
                                                    [enabled] => 1
                                                    [plugin] =>
                                                    [lock_count] => 0
                                                    [last_run] => 1583475930
                                            [_new:protected] =>
                                            [changed] => Array
                                            [skipCloneDuplication] =>
            [5] => Array
                    [line] => 255
                    [function] => execute
                    [type] => ->
                    [args] => Array
            [6] => Array
                    [line] => 224
                    [function] => run
                    [type] => ->
                    [args] => Array
            [7] => Array
                    [file] => /home/users/n/nizhniy-shkaft/domains/domain/applications/core/interface/task/task.php
                    [line] => 63
                    [function] => runAndLog
                    [type] => ->
                    [args] => Array
    [previous:Exception:private] =>
2 часа назад, alcatras сказал:
Вот ошибка
17 минут назад, newbie сказал:
Вот ошибка
тоесть проблема со стороны хостинга? Из-за этого фоновые процессы просто стоят на месте
Изменено пользователем alcatras
