Баннер и меню в шапке!
Здравствуйте!
1) подскажите пожалуйсто как реализовать меню в правую сторону шапки как показано красной стрелкой!
2) как сделать отступ сверху в низ как показано синей точкой
Шапка разбита вот таким спосабом:
http://ipb-ru.net/logo_ipb_3.html
Мой global_board_header:
<!--ipb.javascript.start-->
//<![CDATA[
var ipb_var_st			= "{$this->ipsclass->input['st']}";
var ipb_lang_tpl_q1	   = "{$this->ipsclass->lang['tpl_q1']}";
var ipb_var_s			 = "{$this->ipsclass->session_id}";
var ipb_var_phpext		= "{$this->ipsclass->vars['php_ext']}";
var ipb_var_base_url	  = "{$this->ipsclass->js_base_url}";
var ipb_var_image_url	 = "{$this->ipsclass->vars['img_url']}";
var ipb_input_f		   = "{$this->ipsclass->input['f']}";
var ipb_input_t		   = "{$this->ipsclass->input['t']}";
var ipb_input_p		   = "{$this->ipsclass->input['p']}";
var ipb_var_cookieid	  = "{$this->ipsclass->vars['cookie_id']}";
var ipb_var_cookie_domain = "{$this->ipsclass->vars['cookie_domain']}";
var ipb_var_cookie_path   = "{$this->ipsclass->vars['cookie_path']}";
var ipb_md5_check		 = "{$this->ipsclass->md5_check}";
var ipb_new_msgs		  = {$this->ipsclass->member['new_msg']};
var use_enhanced_js	   = {$this->ipsclass->can_use_fancy_js};
var use_charset		   = "{$this->ipsclass->vars['gb_char_set']}";
var ipb_myass_chars_lang  = "{$this->ipsclass->lang['myass_chars']}";
var ajax_load_msg		   = "{$this->ipsclass->lang['ajax_loading_msg_new']}";
</script>
<script type="text/javascript" src='jscripts/ips_ipsclass.js'></script>
<script type="text/javascript" src='jscripts/ipb_global.js'></script>
<script type="text/javascript" src='jscripts/ips_menu.js'></script>
<script type="text/javascript" src='{$this->ipsclass->vars['img_url']}/folder_js_skin/ips_menu_html.js'></script>
<script type="text/javascript" src='cache/lang_cache/{$this->ipsclass->lang_id}/lang_javascript.js'></script>
//<![CDATA[
var ipsclass = new ipsclass();
ipsclass.init();
ipsclass.settings['do_linked_resize'] = parseInt( "{$this->ipsclass->vars['resize_linked_img']}" );
ipsclass.settings['resize_percent']   = parseInt( "{$this->ipsclass->vars['resize_img_percent']}" );
</script>
<!--ipb.javascript.end-->
<div class="borderwrap">
<div id="logostrip1">
<div style="float:right;padding:0"><img src='style_images/<#IMG_DIR#>/tile_back_r.gif' style='vertical-align:top' alt='' border='0' /></div>
<div id="logostrip"><a href='{$this->ipsclass->base_url}'><!--ipb.logo.start--><img src='style_images/<#IMG_DIR#>/logo4.gif' style='vertical-align:top' alt='IPB' border='0' /><!--ipb.logo.end--></a></div></div>
<div id="submenu">
	<!--ipb.leftlinks.start-->
	<if="$this->ipsclass->vars['home_url']">
		<span class='ipb-top-center-link'><a href="{$this->ipsclass->vars['home_url']}">{$this->ipsclass->vars['home_name']}</a></span>
	</if>
	<if="$this->ipsclass->vars['csite_on']">
		<span class='ipb-top-center-link'><a href="{$this->ipsclass->base_url}act=home">{$this->ipsclass->vars['csite_title']}</a></span>
		</if>
	<!--IBF.RULES-->
	<!--ipb.leftlinks.end-->
	<!--ipb.rightlinks.start-->
	<span class='ipb-top-center-link'><a href="{$this->ipsclass->base_url}act=Help">{$this->ipsclass->lang['tb_help']}</a></span>
	<span class='ipb-top-center-link' id="ipb-tl-search"><a href="{$this->ipsclass->base_url}act=Search&f={$this->ipsclass->input['f']}">{$this->ipsclass->lang['tb_search']}</a></span>
	<span class='ipb-top-center-link'><a href="{$this->ipsclass->base_url}act=Members">{$this->ipsclass->lang['tb_mlist']}</a></span>
	<span class='ipb-top-center-link' style="border-right: 1px solid #dce3ee"><a href="{$this->ipsclass->base_url}act=calendar">{$this->ipsclass->lang['tb_calendar']}</a></span>
	<if="$component_links != """>
		{$component_links}
	</if>
	<div class='popupmenu-new' id='ipb-tl-search_menu' style='display:none;width:210px'>
		<form action="{$this->ipsclass->base_url}act=Search&CODE=01" method="post">
			<input type='hidden' name='forums' id='gbl-search-forums' value='all' />
			<input type="text" size="20" name="keywords" id='ipb-tl-search-box' />
			<input class="button" type="image" style='border:0px' src="{$this->ipsclass->vars['img_url']}/login-button.gif" />
			<if="($this->ipsclass->input['act'] == 'sf' OR $this->ipsclass->input['act'] == 'st') AND $this->ipsclass->input['f']">
				<br /><input type='checkbox' id='gbl-search-checkbox' value='1' onclick='gbl_check_search_box()' checked='checked' /> {$this->ipsclass->lang['gbl_forum_search']}
			</if>
		</form>
		<div style='padding:4px'>
			<a href='{$this->ipsclass->base_url}act=Search'>{$this->ipsclass->lang['gbl_more_search']}</a>
		</div>
	</div>
		ipsmenu.register( "ipb-tl-search", 'document.getElementById("ipb-tl-search-box").focus();' );
		gbl_check_search_box();
	</script>
	<!--ipb.rightlinks.end-->
</div>
</div>
<if="$this->ipsclass->can_use_fancy_js != 0">
<script type="text/javascript" src='jscripts/ips_xmlhttprequest.js'></script>
<script type="text/javascript" src='jscripts/ipb_global_xmlenhanced.js'></script>
<script type="text/javascript" src='jscripts/dom-drag.js'></script>
<div id='get-myassistant' style='display:none;width:400px;text-align:left;'>
<div class='maintitle' id='myass-drag' title='{$this->ipsclass->lang['myass_drag']}'>
 <div style='float:right'><a href='#' onclick='document.getElementById("get-myassistant").style.display="none"'>[X]</a></div>
 <div>{$this->ipsclass->lang['myass_title']}</div>
</div>
<div id='myass-content' style='overflow-x:auto;'></div>
</div>
</div>
<!-- Loading Layer -->
<div id='loading-layer' style='display:none'>
<div id='loading-layer-shadow'>
   <div id='loading-layer-inner'>
 	<img src='style_images/<#IMG_DIR#>/loading_anim.gif' border='0' alt='{$this->ipsclass->lang['ajax_loading_msg']}' />
	<span style='font-weight:bold' id='loading-layer-text'>{$this->ipsclass->lang['ajax_loading_msg']}</span>
	</div>
</div>
</div>
<!-- / Loading Layer -->
<!-- Msg Layer -->
<div id='ipd-msg-wrapper'>
<div id='ipd-msg-title'>
	<a href='#' onclick='document.getElementById("ipd-msg-wrapper").style.display="none"; return false;'><img src='style_images/<#IMG_DIR#>/close.png' alt='X' title='Close Window' class='ipd' /></a>   <strong>{$this->ipsclass->lang['gbl_sitemsg_header']}</strong>
</div>
<div id='ipd-msg-inner'><span style='font-weight:bold' id='ipd-msg-text'></span><div class='pp-tiny-text'>{$this->ipsclass->lang['gbl_auto_close']}</div></div>
</div>
<!-- Msg Layer -->
</if>
<!-- / End board header -->
Огромное спасибо, разобрася! Теперь дальше:
Вот скрин, я на нем пометил цифрами что нужно реализовать:
1) Убрать пробел, сделать слитно
2) Сузить по максимому
3) Убрать этот пробел на котором поместилась цифра "3"
Изменено пользователем BGD
1 - #userlinks : margin: 0;
2 - #userlinks : padding: 0;
3 - global_board_header
найти:
подогнать width
с высотой таблицы с личными данными нечего не вышло! падиг полгосью в 0 сгонял!
Все разобрался! Сделал огромное спасибо!
