Удаление нулевых скриптов
Здравствуйте!
Мне пришло письмо от хостера с уведомлением удалить взломанные(<нулёных>, <nulled>) скрипты на форуме:
Перечень проблемных скриптов:
Script name: Invision Power Board (cracked/nulled)
Script location: /www/hmarka.net/g/o/golos/home/site/sources/acp_loaders
Script location: /www/hmarka.net/g/o/golos/home/site/sources/components_location
Script location: /www/hmarka.net/g/o/golos/home/site/sources/portal_plugins
Script location: /www/hmarka.net/g/o/golos/home/site/sources/components_public/profile
Script location: /www/hmarka.net/g/o/golos/home/site/sources/action_public
Script location: /www/hmarka.net/g/o/golos/home/site/sources/action_public/misc
Script location: /www/hmarka.net/g/o/golos/home/site/sources/sql
Script location: /www/hmarka.net/g/o/golos/home/site/sources/action_admin
Script location: /www/hmarka.net/g/o/golos/home/site/sources/components_init
Script location: /www/hmarka.net/g/o/golos/home/site/sources/handlers
Script location: /www/hmarka.net/g/o/golos/home/site/sources/loginauth/internal
Script location: /www/hmarka.net/g/o/golos/home/site/sources/loginauth/convert
Script location: /www/hmarka.net/g/o/golos/home/site/sources/tasks
Script location: /www/hmarka.net/g/o/golos/home/site/sources/lib
Script name: Cracked/nulled script
Script location: /www/hmarka.net/g/o/golos/home/site/sources/components_acp
Script location: /www/hmarka.net/g/o/golos/home/site/sources/components_acp/setting_plugins
Script location: /www/hmarka.net/g/o/golos/home/site/sources/api
Script location: /www/hmarka.net/g/o/golos/home/site/sources/classes
Script location: /www/hmarka.net/g/o/golos/home/site/sources/classes/post
Script location: /www/hmarka.net/g/o/golos/home/site/sources/classes/bbcode
Script location: /www/hmarka.net/g/o/golos/home/site/sources/classes/editor
Script location: /www/hmarka.net/g/o/golos/home/site/sources/classes/class_virus_checker
Script location: /www/hmarka.net/g/o/golos/home/site/upgrade/core
Script location: /www/hmarka.net/g/o/golos/home/site/upgrade/core/actions
Подскажите как правильно это сделать пошагово чайнику плиз!
И не повлияет после этого удаления на работу форума?
Изменено пользователем Yarkop
Купите лицензию и не будет проблем)
А другие способы?)
А другие способы?)
Хостера сменить...
Хостера сменить...
А как на счет коректного и правильного удаления?
Купите лицензию и "предъявите" хостеру.
Замените файлы форума из дистрибутива (лицензионного), но если форум модифицирован, моды слетят.
Переезд на другой хостинг не поможет, если новый хостинг не абузоустойчивый (абузоустойчивый гораздо дороже), так как IPS наверное хостеру письма шлет насчет вашего форума.
Стукануть могли конкуренты (остальным нафик не надо).
Переедете, другой хостер потребует убрать нулленые скрипты, так как письма и ему придут.
Домен смените, трафик потеряете, да и конкуренты все равно снова стуканут.
Если Вы иждивенец и не имеете возможности купить скрипт, имеет смысл копирайты по всей форме оформлять. Это в какой-то мере спасет от стука. У Вас небось в копирайтах "нуллед"?
А вообще, если нет денег, лучше использовать бесплатные скрипты. И честно, и спокойно.
Наверное так и сделаю.
Не подскажите нубу где искать? И какие именно?
П.С. СПС!
phpbb форум, smf форум....
Есть масса бесплатных движков.
IPB, начиная с версии 2.0, – платный продукт. Если проект серьезный, конкурентный, расчитан на монетизацию, рисковать, используя нулл, глупо.
Нуллы, – это для школьников, у котоых и форумы недолго живут.
