Создание блока портала(синтаксис)
Создаю блок вида:
Случайное фото галереи
<?php
echo('<Center><table border=0><TR>');
$MZresult = $this->DB->query("SELECT newipb_gallery_images.id as picid,newipb_members.members_display_name as mname,`file_size`,`medium_file_name`,`masked_file_name`,`directory`,`caption`,`description`,`comments`,`views`
FROM `newipb_gallery_images` , `newipb_members`
WHERE newipb_gallery_images.member_id = newipb_members.member_id and newipb_gallery_images.approved=1 and newipb_gallery_images.pinned=1
ORDER BY rand() LIMIT 1");
WHILE ($MZrow = $this->DB->fetch($MZresult))
if (($MZrow['file_size']) < 90000)
{ echo('<TD ALIGN=center width=99%><a href="../index.php?app=gallery&module=images&section=viewimage&img='.$MZrow['picid'].'">');
echo('<B>'.$MZrow['caption'].'</B><BR><BR><IMG SRC="../uploads/');
echo($MZrow['directory']. '/'.$MZrow['masked_file_name'].'" alt="click HERE more info on the image"'. 'class="linked-image"'. 'border=0 ></a><BR><i>'.$MZrow['description'].'</i><BR><BR>Добавил '.$MZrow['mname'].'<br><img src="../public/style_images/fantasy/comments.png">  <b>Коментарий</b>: '.$MZrow['comments'].' :: <a href="../index.php?app=gallery&module=images&section=viewimage&img='.$MZrow['picid'].'">Просмотр коментарий</a>');
echo (' :: <img src="../public/style_images/fantasy/blog/views.png">  Views: '.$MZrow['views'].'</TD></TR></TR>');
else
{ echo('<TD ALIGN=center width=99%><a href="/index.php?app=gallery&module=images&section=viewimage&img='.$MZrow['picid'].'">');
echo($MZrow['directory']. '/'.$MZrow['medium_file_name'].'" alt="click HERE more info on the image"'. 'class="linked-image"'. 'border=0 ></a><BR><i>'.$MZrow['description'].'</i><BR><BR>Добавил '.$MZrow['mname'].'<br><img src="../public/style_images/fantasy/comments.png"> <b>Коментарий</b>: '.$MZrow['comments'].' :: <a href="/index.php?app=gallery&module=images&section=viewimage&img='.$MZrow['picid'].'">Просмотр коментарий</a>');
echo('</TR></TABLE>');
Болк не отображается скрин прилагается!
Создаю блок CS мониторинга, тоже самое!
создаю блок ХТМЛ все нормуль! А ПХП не получается мб с синтаксисом что не правильно?
мне бы тоже понадобилась такая вещь, так как на 3.0.4 у меня не выходит установить Custom Sidebar Blocks вроде устанавливается, а в итоге не работает нечего :( вот мне тоже бы не помешал блок на форуме справа, и чтобы его самому вставить можно было.
Вставлять свой php код?
так как на 3.0.4
Лучше обновится до 3.0.5
(e$30) Custom Sidebar Blocks ставили с нормального ресурса? Тогда будет работать.
у меня с данным модам проблем, я его вроде устанавливаю всё окей, но после того как в админке, в меню наверху в приложения я нажимаю на него, меня просто выкидывает на главную страницу админки :)
Значит что-то неправильно установилось.
