Jump to content
Search In
  • More options...
Find results that contain...
Find results in...
Sign in to follow this
aksen1488
Небольшая проблема с ipb 3.1.4
Recommended Posts
Да, раньше всё было нормально, после того как убрал $INFO['board_url'] появилась такая проблема.
Его убирать не надо было. Поставил форум на local-хост. Использовал ваш домен. Инсталлятор прописал conf_global.php так:
<?php
$INFO['sql_driver']			=	'mysql';
$INFO['sql_host']			=	'localhost';
$INFO['sql_database']			=	'talk';
$INFO['sql_user']			=	'root';
$INFO['sql_pass']			=	'';
$INFO['sql_tbl_prefix']			=	'ibf_';
$INFO['sql_debug']			=	'0';
$INFO['board_start']			=	'1291563634';
$INFO['installed']			=	'1';
$INFO['php_ext']			=	'php';
$INFO['safe_mode']			=	'0';
$INFO['board_url']			=	'http://xn--80abnzdiz4dp1c.xn--p1ai';
$INFO['banned_group']			=	'5';
$INFO['admin_group']			=	'4';
$INFO['guest_group']			=	'2';
$INFO['member_group']			=	'3';
$INFO['auth_group']			=	'1';
$INFO['use_friendly_urls']			=	'1';
$INFO['_jsDebug']			=	'0';
$INFO['mysql_tbl_type']			=	'MyISAM';
define('IN_DEV', 0);
Все работает. Нечего менять не пришлось.
Share this post
Link to post
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Create New...
