bb-code + geshi
И так. Geshi - набор классов и функций для красивого отображения различных языков программирования.
Архив
Php файл bb-code.
Строго не судите т.к. это мои первые шаги (я сам программист c, c++, asm).
<?php
class bbcode_cppcode extends bbcode_parent_class implements bbcodePlugin
 * Constructor
 * @access	public
 * @param	object		Registry object
 * @return	void
public function __construct( ipsRegistry $registry )
	$this->currentBbcode	= 'cppcode';
	parent::__construct( $registry );
public function preDbParse( $txt )
	return parent::preDbParse( $txt );
public function preDisplayParse( $txt )
	return parent::preDisplayParse( $txt );
 * Do the actual replacement
 * @access	protected
 * @param	string		$txt	Parsed text from database to be edited
 * @return	string				BBCode content, ready for editing
protected function _replaceText( $txt )
	$_tags = $this->_retrieveTags();
	foreach( $_tags as $_tag )
		$open_tag	= '[' . $_tag;
		$close_tag	= '[/' . $_tag . ']';
		while( ( $this->end_pos = stripos( $txt, $close_tag, $this->end_pos ) ) !== false )
			$this->cur_pos	= $this->end_pos;
			while( $this->cur_pos > 0 )
				$this->cur_pos = $this->cur_pos - 1;
				if( $this->cur_pos < 0 )
					break;
				if( stripos( $txt, $open_tag, $this->cur_pos ) === $this->cur_pos )
					$open_length	= strlen($open_tag);
					$_content	= substr( $txt, ($this->cur_pos + $open_length + strlen($_option) + 1));
					$txt = substr_replace( $txt, $this->_buildOutput( $_content), $this->cur_pos, (stripos( $txt, $close_tag, $this->cur_pos ) + strlen($close_tag) - $this->cur_pos) );
					break;
			$this->end_pos += 1;
			if( $this->end_pos > strlen($txt) )
				$this->end_pos	= 0;
				break;
	return $txt;
 * Raw options string
 * @access	private
 * @param	string		$string		The options submitted with the post as a string
 * @return	array					Key => value Option pairs
private function _extractSurgicallyTehOptions( $options='' )
	return $finalOpts;
 * Build the actual output to show
 * @access	private
 * @param	integer		$option		Font size
 * @param	string		$content	Text
 * @return	string					Content to replace bbcode with
private function _buildOutput( $content)
	// Include the GeSHi library//
	require_once('***************/includes/geshi.php');
	//// Define some source to highlight, a language to use
	// and the path to the language files//
	 $lang = 'cpp';
	 $geshi = new GeSHi($content, $lang);
	return  $geshi->parse_code();
Ввожу у себя на формуе:
[cppcode]
#include <iostream>
using namespace std;
[/cppcode]
Цвет, отступы распознает, но
получаю:
<br />
#include <iostream><br />
using namespace std;<br />
Хотя отдельно php скрипт пашет без проблем. Как быть?
но получаю:
Это от того что Geshi кодирует спецсимволы в хтмл сущности, потом строка еще раз проходит через форумный кодировщик. Получается спецсимволы кодируются два раза. Надо либо в геши отключить, либо декодировать на выходе из него - htmlspecialchars_decode( return $geshi->parse_code() );
Попробую потыкаться в настройках.
Проблема еще не устранена.
И так код:
#include <iosream>
void main()
cout<<endl;
Без декодирования (как было в 1ом сообщении):
<br />
#include <iosream><br />
void main()<br />
{<br />
cout<<endl;<br />
}<br />
С:
<br />
#include <iosream>
void main()<br />
{<br />
cout<<endl;<br />
}<br />
Изменено пользователем DJ_Vasek
