Ошибка с базой
Вот что логи ьпоказывают....честно не знаю как решить проблему(
Date: Tue, 11 Oct 2011 17:07:02 +0000
Error: 145 - Table './forum/sessions' is marked as crashed and should be repaired
IP Address: 91.218.38.229 - /forum/public/style_images/habtastic/_custom/icon_primary_blog.png
mySQL query error: DELETE FROM sessions WHERE (member_id=5) OR running_time < 1318349222
| admin/sources/classes/session/publicSessions.php | [db_main_mysql].delete | 1209 |
| admin/sources/classes/session/publicSessions.php | [publicSessions]._destroySessions | 838 |
| admin/sources/classes/session/publicSessions.php | [publicSessions]._createMemberSession | 474 |
| admin/sources/base/ipsRegistry.php | [publicSessions].__construct | 3639 |
| admin/sources/base/ipsRegistry.php | [ips_MemberRegistry].init | 3476 |
| admin/sources/base/ipsRegistry.php | [ips_MemberRegistry].instance | 588 |
Date: Tue, 11 Oct 2011 17:07:07 +0000
IP Address: 91.218.38.229 - /forum/index.php?/forum/9-%d0%b0%d0%bd%d0%b8%d0%bc%d0%b5-%d0%be%d0%b1%d1%81%d1%83%d0%b6%d0%b4%d0%b5%d0%bd%d0%b8%d0%b5-%d0%be%d1%82%d0%b4%d0%b5%d0%bb%d1%8c%d0%bd%d1%8b%d1%85-%d0%bf%d1%80%d0%be%d0%b8%d0%b7%d0%b2%d0%b5%d0%b4%d0%b5%d0%bd%d0%b8%d0%b9/
mySQL query error: SELECT * FROM sessions WHERE id='ad05a66f77dd818e3f74906b5defb7c9'
| admin/sources/classes/session/publicSessions.php | [publicSessions].getSession | 341 |
Date: Tue, 11 Oct 2011 17:07:12 +0000
Date: Tue, 11 Oct 2011 17:07:17 +0000
IP Address: 91.218.38.229 - /forum/index.php?/topic/74-%d0%ba%d0%b0%d0%ba-%d0%be%d0%b7%d0%b2%d1%83%d1%87%d0%b8%d0%b2%d0%b0%d1%8e%d1%82-%d0%b0%d0%bd%d0%b8%d0%bc%d0%b5/
Date: Tue, 11 Oct 2011 17:07:23 +0000
IP Address: 91.218.38.229 - /forum/index.php?/forum/12-%d0%bc%d0%b0%d0%bd%d0%b3%d0%b0/
Date: Tue, 11 Oct 2011 17:07:26 +0000
Решил проблему починкой таблицы sessions ....сразу не додумался((
так... А из за чего могла такая быть ошибка? что бы не повтарилась( спасибо
Креш таблиц идет от нехватка рессурс сервера. Чаще всего это память.
