перенос
Здравствуйте, зря написал что нашел где изменять все.
Я перешел на другой хостинг, восстановил БД в phpmyadmin. Потом залил форум (тот который раньше был, т.е не стал заново устанавливать)
изменил данные в conf_global.php, но я так думаю это не все. При добавлении коммета вылезает:
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/var/www/ТУТ СТАРАЯ ССЫЛКА/forum/uploads) is not within the allowed path(s): (/home/comman:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/comman/public_html/forum/admin/applications/core/sources/classes/attach/class_attach.php on line 1484
Warning: Cannot modify header information - headers already sent by (output started at /home/comman/public_html/forum/admin/applications/core/sources/classes/attach/class_attach.php:1484) in /home/comman/public_html/forum/ips_kernel/classAjax.php on line 288
Warning: Cannot modify header information - headers already sent by (output started at /home/comman/public_html/forum/admin/applications/core/sources/classes/attach/class_attach.php:1484) in /home/comman/public_html/forum/ips_kernel/classAjax.php on line 295
Warning: Cannot modify header information - headers already sent by (output started at /home/comman/public_html/forum/admin/applications/core/sources/classes/attach/class_attach.php:1484) in /home/comman/public_html/forum/ips_kernel/classAjax.php on line 296
Warning: Cannot modify header information - headers already sent by (output started at /home/comman/public_html/forum/admin/applications/core/sources/classes/attach/class_attach.php:1484) in /home/comman/public_html/forum/ips_kernel/classAjax.php on line 297
и потом еще всякий бред, но коммент добавляется.
и в ПУ вот это сверху:
Warning: is_dir() [function.is-dir]: open_basedir restriction in effect. File(/var/www/ТУТ СТАРАЯ ССЫЛКА/forum/uploads/profile/) is not within the allowed path(s): (/home/comman:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/comman/public_html/forum/admin/applications/core/extensions/dashboardNotifications.php on line 146
Изменено пользователем ivashka71reg
пожалуйста подскажите
  • 8 месяцев спустя...
такая же штука
В глобальных настройках форума путь к папке "uploads" измените на новый.
