IPB 3.2.3 Баги
Залил на сервер нову версию форума 3.2.3 на английском. Не успел установить, а уже 500-я ошибка вылетает. Логи ошибок:
[Fri Oct 21 03:53:28 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 03:55:56 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 03:58:24 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:00:52 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:03:21 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:05:49 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:07:37 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542, referer: http://forum.onlygoodanime.ru/topic/23-f-a-q/nextunread/
[Fri Oct 21 04:07:39 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542, referer: http://forum.onlygoodanime.ru/
[Fri Oct 21 04:08:17 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:10:47 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:13:15 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:15:42 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:18:10 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:20:38 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:23:06 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:25:33 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:28:01 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:30:29 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:31:29 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:32:57 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:35:24 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:37:52 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:40:19 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:42:47 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:45:15 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:47:42 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:50:10 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:52:38 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:55:05 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 04:56:10 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 05:16:29 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 05:37:50 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 05:47:13 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 06:04:08 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 06:07:20 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 06:07:46 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 06:44:12 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 07:10:04 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542, referer: http://vstatus.net/
[Fri Oct 21 07:10:04 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542, referer: http://forum.onlygoodanime.ru/
[Fri Oct 21 07:10:05 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542, referer: http://forum.onlygoodanime.ru/
[Fri Oct 21 07:50:33 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 07:58:06 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 08:19:57 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 09:21:03 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 09:27:57 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 09:37:56 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 10:07:52 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 10:16:20 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
[Fri Oct 21 11:11:38 2011] [error] [client 188.120.236.74] PHP Parse error:  syntax error, unexpected T_STRING in /home/storok/data/www/forum.onlygoodanime.ru/ips_kernel/classDbMysqliClient.php on line 542
Что посоветуете? Откатить до строй версии и подождать стабильного релиза? Или здесь что с настройками сервера не так?
Причём все ошибки одинаковые...
А саппорт по месту покупки форума как реагирует на Ваши жалобы?
Вначале пусть они дадут совет.
Скахали что скорее всего проблема связана снепраильной заливкой файлов на сервер. Попробуйте снова. Перезалил. Сейчас обновляю до новой версии.
Всё обновил. Работает без багов.
