Ошибка БД при обновлении.
Здравствуйте.
Кто может помочь с данной проблемой.При обновлении с ipb 3.0.5 на 3.1.0 на странице ...upgrade&do=templatecache вылетела ошибка бд.
Сама ошибка:
Error Number: 1064
Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND ( ( css_set_id > 0 AND css_master_key='' ) OR ( css_set_id=0 AND css_maste' at line 1
Page: /admin/upgrade/index.php?app=upgrade&section=upgrade&do=templatecache
Debug: array (
 1 =>
 array (
   'file' => '/home/tfreemeg/public_html/ips_kernel/classDb.php',
   'line' => 1050,
   'function' => 'query',
   'class' => 'db_driver_mysql',
 3 =>
 array (
   'file' => '/home/tfreemeg/public_html/admin/sources/classes/skins/skinCaching.php',
   'line' => 704,
   'function' => 'fetchCSS',
   'class' => 'skinFunctions',
 4 =>
 array (
   'line' => 561,
   'function' => 'rebuildCSSCache',
   'class' => 'skinCaching',
 5 =>
 array (
   'file' => '/home/tfreemeg/public_html/admin/setup/applications/upgrade/sections/upgrade.php',
   'line' => 1477,
   'function' => 'rebuildCSS',
 6 =>
 array (
   'line' => 208,
   'function' => 'install_template_caches',
   'class' => 'upgrade_upgrade',
 7 =>
 array (
   'file' => '/home/tfreemeg/public_html/admin/setup/sources/base/ipsController_setup.php',
   'line' => 255,
   'function' => 'doExecute',
mySQL query error: SELECT *,INSTR(',,', CONCAT(',',css_set_id,',')) as theorder FROM skin_css WHERE css_set_id IN () AND ( ( css_set_id > 0 AND css_master_key='' ) OR ( css_set_id=0 AND css_master_key='root' ) ) ORDER BY css_group, theorder DESC
Изменено пользователем bukasuka
вроде нашёл где собака порылась, но всеравно очень нужна ваша помощ:
выдаёт мне sql запрос (
INSERT INTO ibf_cache_store ( cs_key , cs_value , cs_extra , cs_array , cs_updated ) VALUES ( 'rss_output_cache', '' , '', '1', '0' );
INSERT INTO ibf_rc_classes (onoff, class_title, class_desc, author, author_url, pversion, my_class, group_can_report, mod_group_perm, extra_data, lockd) VALUES(1, 'Пример плагина', 'Плагин, не требующий написания кода, но требующий настройки.', 'Invision Power Services, Inc', '', 'v1.0', 'default', ',3,4,6,', ',4,6,', 'a:5:{s:14:"required_input";a:1:{s:8:"video_id";s:13:"[^A-Za-z0-9_]";}s:10:"string_url";s:41:"http://www.youtube.com/watch?v={video_id}";s:12:"string_title";s:25:"#PAGE_TITLE# ({video_id})";s:13:"section_title";s:7:"YouTube";s:11:"section_url";s:22:"http://www.youtube.com";}', 1);
так вот самой таблицы в ibf_rc_classes базе нет; кто-то может подсказать с какими точно данными надо создать таблицу?
и эту по ходу тоже ibf_rc_status;
таки нет не здесь эта проблема, с базой все исправил, всеравно выкидывает и дальше обновлятся нив какую
Изменено пользователем otoman
единственное подставлял вместо кои - латин и вместо 1251 - утф8,
И что получили? Какая у вас реальная кодировка?
та вообще ничего не получил форум не стартует, а на admin/upgrade/ заходит дохожу до обновлений все делаю, каждую команду перепроверяю в мускуле, а потом выбивает после одной из страниц.
а в базе mysql> show create database o_db;
| Database | Create Database |
| o_db | CREATE DATABASE `o_db` /*!40100 DEFAULT CHARACTER SET utf8 COLLATE utf8_unicode_ci */ |
@otoman, зайдите в phpmyadmin, потом в вашу базу и выполните запрос
show variables like '%char%';
Должены получить вот такой результат
Можно еще и такой чтобы наверняка
show variables like '%coll%';
таки нет, так а это вроде как настройка самого мускуля тоесть его конфигов
у меня только character_set_system | utf8
блина а как поменять по ssh
блин остался только server в utf8 перенести никто не подскажет???
Board URL: localhost - какой ssh на localhost?
Поменять настройки в my.cnf
Это все конечно интересно, но таблицы форума в какой кодировке?
utf8
utf8
и самое обидное что теперь не хочет принимать логин и пароль, не могу зайти чтобы обновится,а если делаю дамп старой базы прохожу опять все заново но приходится играться с мускулем постоянно, то все переводить в утф то обратно в латин1.
и кстате скин с 2.3.3 останется если всетаки осилю перебить до 3.2 форум???
Зачем два раза играться? У вас должны быть два бэкапа, первый - оригинал базы, второй - конвертированный в utf-8. Рано вы что-то начали делать обновления, вам бы форум да faq почитать.
Кодировку mysql сервера необязательно каждый раз менять при смене базы, можно установить cp1251 или utf8 по умолчанию. У меня например
| Variable_name            | Value                             |
| character_set_client     | cp1251                            |
| character_set_connection | cp1251                            |
| character_set_database   | cp1251                            |
| character_set_filesystem | binary                            |
| character_set_results    | cp1251                            |
| character_set_server     | cp1251                            |
| character_set_system     | utf8                              |
| character_sets_dir       | \usr\local\mysql5\share\charsets\ |
и прекрасно все работает
нет
где-то видел скин "а-ля 2.3", но он под 3.1 (да и не совсем как 2.3 он выглядит)
у меня пошагово несколько баз сохранено, и чесно говоря уже запутался, начал все сначала, поставил форум, поменял папки, запустил обновлялку и теперь доходит только до выбора Экспортировать текущие шаблоны и CSS? (Будут сохранены в директории /cache/previousSkinFiles) и тд и тп, но дальше просто Ошибка HTTP 503 (Service Unavailable): бла бла бла и все, и кто блин знает что за фигня, раньше хоть запросы в мускуль показывало, и на каком-то шаге тупило, сейчас и до этого не доходит.
и кодировочку тоже сейчас у меня
| character_set_client | latin1 |
| character_set_connection | latin1 |
| character_set_database | latin1 |
| character_set_results | latin1 |
| character_set_server | latin1 |
| character_sets_dir | /usr/share/mysql/charsets/ |
8 rows in set (0.00 sec)
В логов при этом ничего не пишется?
логи базы? ща посмотрим
проблемный короче я пасажир, логи ничерта не пишутся, буду с логами тогда пока разбираться.
